priorityelec
- Sep 11, 2020
- 37
So I went with the LV6548. It has 2 mppt inputs both at 4kw. I have 24 panels. My plan is to do a series of 6 panels, then parallel 2 of these together with an mc4 branch connector. I'd do this same setup for each mppt connection. I figure I'd put a 15 amp fuse at the end of each series just before it connects to the branch connector.
Each mppt would then have 12 panels hooked up.
My panels are the santan solar 240 watt panels rated at 37.2voc, 30.4v vmp, and 7.89 amps.
My big questions is how do I properly fuse this? Is an inline fuse at the end of each series enough? I'd have 4 total. Do I need a combiner box? Thanks for any help you can provide.
