frankz66
Hello everyone, I currently have a 12 v solar system with 2.5 kw storage.
The plant is composed as follows:
4 solar panels ( PERC ) 12 volts 2s2p VOC total 46 volts 18 amps .
1 epever 6415AN Tracer
1 Pure wave inverter 1000w 2000w max 12 volts EDECOA
4 AGM batteries 110 amps 12v in parallel tot 440 amps and 2.6 kw available with 50 % DOD. .
In fact, I wanted to know some advice on what I can do to improve the system. In addition, if I connect the batteries in series to obtain 24 volts and 200 amps, what benefits do I bring to the system? I connected the refrigerator, which absorbs 500 watts for 1 second causing a voltage drop of 0.70 volts. If I connected the 24v battery system, will I improve something or not?
Clearly I would have to change the inverter to 24 volts .
The epever with 24 volts of batteries, the technical table tells me that it is able to errone in charging towards the batteries well 1500 watts.
