Crunchiness
Hi, new guy here looking to develop a small solar setup for an off-grid bathroom.
Goal: Have a low-maintenance system to power the following items of an off-grid bathroom used in some backcountry skiing operations:
There will be a generator available ( 25kw genset) for approximately 2-3 hrs every couple of days, but due to the nature of the operation we would like to keep the bathroom running all the time ( Users need a bio-break at any time)
-2 Propane interaction toilets - 12v (using a 120 to 12v adapter) @ 1.3a per "flush" for 15min each - Expect a total of 6 flushes a day - 24wh/day
-12 ea 15w lights - run for 8hrs run time per day - 960wh/day (guests leave the lights on)
-Small propane water heater- 400wh/day
-Small water pump- 400wh/day
1.384 kwh/day - x 1.20 for passive loads - 2051wh/d
Therefore I`m planning on a 4800 kWh system to provide two days of runtime.
These are calculated using worst-case scenarios.
These are the products I`m looking at right now:
48v inverter
2 x 24v LiPo4 BATTERY
We already have 4 of these panels from a recycled radio repeater: Panel
The questions I have:
- I need to run a 100ft wire from the panels to the inverter to get them in a good spot (max sun). The above inverter has a Built-in MPPT - This will allow me to run the panels in a series to minimize the need for a heavy gauge wire to the panel- Correct?
My calculations show that an 8AWG cable will allow for less than 3% voltage drop. Does this feel right?
(I'm using a 1.25 factor due to cold weather on MPV and MPP (Conservative) )
-The batteries are self-heated, but should only be used in case of a failure of the propane heating system for the bathroom. How reliable is this system? Are there self-heating batteries at a similar pricepoint elsewhere? Not savvy to all the good sites to look for things.
-These are 24v Batteries. I`m planning on wiring in a series to jump to 48v. The manual says this is possible... anything seem like it wouldn't work by doing this?
-The budget is $4000. I figure I`m probably going to spend $1500 on conduit/assorted wiring/connectors/etc. That leaves me around $500 more to spend... anything else I should consider for a setup like this at that price point?
Thanks! I've used to residential electrical and heavy electrical, but this small-scale solar is head-scratching at times.
48v inverter
