Not quite.
Grid-tied - turns all solar energy into AC power and sends it to your service panel. To be used or exported to the grid.
Off grid - take the solar energy and sends it to a battery storage system. And it can either be used or stored for later use.
AIO- is an All In One unit that has a SCC (Solar Charge Controller), AC charger, inverter, and transfer switch. All In One enclosure.
Hybrid - is a combination of Grid-tied and off grid.
Got it - I don't want grid-tied. Only want solar to feed essential house panel, never back to grid (which I don't even know if they allow here or not)
But an AIO is much cheaper than buying all of the separate (pre-made) devices. Installing them and connecting them together.
I didn't describe my intent very well. From scratch I meant buy the separate components and hook them together. I didn't mean to imply that I would be designing and soldering boards for inverters, SCC etc. I thought maybe buying a separate SCC, inverter and switch would be cheaper and more easily customized than having to go with whatever is commercially available
Blurb time!
Well, I'll start the default answer to these questions and we can work from there. Here's you To-Do list:
Thanks for all the info in your reply. At this stage the system would mostly be meant to run basics...fridge, microwave, some lights...that's probably about it. Maybe 24-48hrs maximum. So the system wouldn't need to be all that big. However, I do have room to upsize in the future as there is a basement with 9ft ceiling that has at least 50-100sq ft that could be dedicated to equipment.
I think a good starting point to determine sizing is assume fridge is running 75% of the day at maybe 400w and then just make sure enough wattage is available to run microwave (1000w) and a few hundred watts of lighting (we have all LED) and some simple low-power stuff like phone chargers. I've seen some 2400-3000w AIO units and thought that would be drastically under-sizing things, but now that I listed out the meager demands for this project I'm thinking that might be just fine. With fridge and microwave running that would leave another 1000-1500W for lights and other stuff. Could probably get away with TV, computer etc.
Here's my thoughts on the calculations for a 24hr outage:
Fridge = 400w x (.75x24)hr = 7,200wh
Microwave = 1000w x 0.5hr = 500wh
Other "stuff" = 500w x 12hr = 6000wh
TOTAL = 13,700wh (let's just round to 14kwh)
I'm not sure whether it is better to run 12, 24, 36 or 48v, but here are a few calculations for battery capacity assuming LFP chemistry:
14kwh/12v = 1166ah so let's just say 1200ah, so 4s12p of 100ah cells or 4s4p of 300ah cells
14kwh/48v = 291 so lets just say 300ah, so 16s3p of 100ah cells or 16s1p of 300ah cells
I'm sure there are losses in the system for efficiency etc, but the above calculations would basically assume total darkness for the entire 24hr period with no help from the solar panels. So assuming there is about maybe 600w - 800w of solar (two panels at 300w-400w each) and at least some sunlight during the 24hr period, then perhaps these numbers work out.
Do the above calculations seem to make general sense, or am I really off here?
Also, any recommendations for AIO units? Ones that are good? Those to avoid? Best place to buy/acquire?
For solar panels I'd scrounge FB Marketplace/Craigslist for used/refurbished unless somebody else has a good source.
For batteries I'd probably look at auctions at Battery Hookup because used cells at 80-90% capacity from an auction would still be 1/2-1/4 the price of new. I've got plenty of space, so even if I got 18-20kwh of "rated" battery capacity that produced 14-16kwh actual then that would be fine.
I don't really have a budget in mind, this is more something that if cost is reasonable enough that I would do it.
*3000w AIO = $500?
*Solar = $300 (I've gotten some before for this price, currently see 400w used panels for $150 each)
*Battery Storage = $1k-$2k (BH right now has brand new cells testing at over 300ah at $450 for 4 of them, so $1800 new. Might be able to snag a random auction for half that cost)
*Misc wires, connectors, breakers, mounting for panels, etc -- $400-$600?
Reasonable estimate = $2500?
Now that I look at the costs, I'm wondering if getting more solar and less battery would be more cost effective? I could get 3 of the 400w panels for same price as 300ah battery storage. Using 4 panels instead of 2 only adds $300 of cost but might allow for reducing battery cost by $400-$900.
