UberTenere
- Aug 17, 2021
- 1
Lets consider an affordable hybrid inverter like the 6kw growatt or one of its similar variants. I'm assuming the listed max PV array power of 5KW is based off the 80A PV charge current X 62.5V which is higher than 54V for charging 48v Battery bank. So my question is do you stay under 5kw array or can you push 5-10% over 5kw based off rated wattage of the panels? With voltage drop and other inefficiencies the full rated power is unlikely to reach the inverter (In North Carolina so im assuming the panels will always be hot). Is it silly to reach for the ideal, or just play it safe since in the end it doesn't really matter?
