jarred125
- Jul 16, 2021
- 125
I finally have my system up, sort of.
Following the Solark 30 minute video they indicate to check the “no battery” option if you, indeed, have no battery. We are grid tied, and when checking that setting the system won’t power any loads from the grid or PV. Disabling that setting brings power back but it is apparently in bypass mode (normal LED is off).
Attached is my current view of the LCD. Any help is appreciated, Solark is currently closed so no support at the moment.
Edit for future people: Be patient, when moving to no battery mode the SolArk takes about 5 minutes after a reboot (you won't have power). You will then hear a click, the load side should now be energized (you can check the buss bars connecting to the load breaker to verify) and you can turn on the breaker.
