Kev12853
Hi, recently had Solax system fitted (X1-Hybrid-G4 5.8 with 2 x 5.8 batteries. I'm trying to get my head around the inverter settings. Main problem is that the phraseology used in the manual is different to that in the actual setting screen, eg Manual says 'Active charging time period' settings screen says 'Forced charge period' I assume these are the same thing. What I am trying to accomplish is this...
My supplier (Octopus) is currently offering, on an ad hoc basis, 2 or 3 hours of FREE electric at various times of the day, today is the first day between 1400 and 1600. I want to use this to charge my batteries if required, heat my hot water tank, do the washing etc. How do I set this up? At the moment I have set the following
Mode = Self use
Forced Charge Period Start time = 14.05
Forced Charge Period End time = 15.55
This I hope will force the grid to supply anything required that is above what the PV can generate. Normally these are both set to 00.00 ie off.
Also I have...
Allowed Discharge Period Start time = 00.00
Allowed Discharge Period End time = 23.59
These are the normal settings for discharge but will this conflict with the Forced Charge Period settings?
I hope this makes sense, any help is gratefully received.
Many thanks
Kevin
Mode = Self use
Also I have...
Many thanks
Kevin
