Dear all,
i am unclear if I misconfigured my solis, or if the seen behavior is as is. kindly asking the experts.
When my pv is generating some small (<700w) overhead, then my solis starts charging the battery. Mode is self-use.
Problem is, it charges to heavy (beyond the 700w available) and then Solis takes power from grid. What happens next , the solis realises that negative from grid and instead of just stopping to charge or lower the charge it even discharges the batt to compensate.
as my pv already had 700w spare and then in Addition the discharge from the solis results in sending to much into grid.
well, you guess what Happens then. Solis stops discharging and goes for full power charging again and triggers above pain by charging to heavy…
this situation even persists over minutes…
actually I am experimenting with the ramp-rate setting, which was at default 600%. tomorrow morning I will see if my actual setting of 30% ramprate is any good.
using the II from mine seplos bms to enforce a small „discharge“ mitigated the issue. However Incan not always sit in front of mine pc and tryjng to compensate a messed-up control-loop by mangling the bms…
any feedback very much appreciated.
