Hi
Thought I would share my experience getting a Solis storage inverter working. I read a lot of posts here of people having issues with Solis inverters and thought I would share this in case it helps anyone.
My setup
Solis RAI-3K-48ES-5G inverter (obviously)
48v 100ah battery with PaceBMS
10 x 405w Ja Solar panels
InfiniSolar V 6kw inverter (for the panels)
Acrel ACR10 3phase energy monitor (single phase, mains electricity)
The big 2 problems have been getting the PaceBMS to talk to the Solis inverter, honestly I gave up and it's set up as a lead acid battery, the charge from grid is limited to just under 2.5kw but that's fine.
The other problem was getting the Acrel meter to talk to the Solis inverter. The meter shipped with a configuration address set to 005 and needs to be 001. Also I had Solis tech support on email all day and went through 2 firmware updates, the first got the CT clamp connected to the solar inverter feed registering the second, may not have been needed.
Also in the Solis needed the meter set to type 3 phase, I thought since I was only monitoring a single phase that would have been correct but no.
Finally I now have this reporting which looks mostly accurate. The exported today is way off but I will see how that looks tomorrow.
My setup
