Hi, I have the Solis RAI-3K-48ES with 16x PV and 2x Pylontech 2.4kWh batteries and I have a few issues hopefully somebody has come across before.
Firstly, I can't see a 'self use' mode inside the storage mode settings. I only see 'Time charging', 'Off Grid mode' and 'Reserve Battery'. From reading this forum it seems other users are using the 'self use' mode.. I wander if I'm on an older firmware and require an update. Looking via the Solis app I'm using inverter version: 220013.
Below shows what my current setup is inside the 'Time Charging' mode:
![1668159269879.png 1668159269879.png](https://diysolarforum.com/data/attachments/119/119814-2004f26fc0adea8c949558e3b97b8533.jpg)
The manual is hard to understand, but what I want to do is slowly charge the batteries (also try and power some of the house) throughout the day using the PV's and then use the batteries during the peak hours so I have set the 'Charge Time' to 06:00 - 17:00 and then 'Discharge Time' from 17:00 to 05:00. My issue is that when I go to sleep around 1am the batteries are at around 20% which is good as they have slowly trickled down, but when I wake up in the morning at around 8am the batteries are now fully charged again. So I must be charging them via the grid during the night?
My other issue is that the Solis wifi stick is very unreliable and is disconnecting every hour meaning I have to keep reconnecting it to my Wifi. Has anyone come across this before? The signal strength is good so maybe the stick is just malfunctioning. I see they do a LAN version that I could run an ethernet cable to my router so that could be my solution.
Finally, has anyone got any recommendations for any DIY logging systems they have setup
I really appreciate any help on this as i'm a complete newbie to all of this but excited to get things working!
Thanks,
Sam
Thanks,
Sam
