[SOLVED] HEYO BMS gives 3.1 V on P-
oskar
So, I'm trying to connect the BMS to the battery pack I just assembled. Battery voltage is OK (cells and total) but BMS is showing low voltage when the balance leads are connected.
And the same low voltage when B- is connected
Also, resistance över B- and P- when only balance is connected is infinite.
Any ideas where to start troubleshooting this? Maybe I'm missing some step that's not documented
Battery pack
4x LifePo4 cells
3.27 - 3,28V per cell
13,1 V total
BMS: HEYO 4S 100A
Aliexpress
Balance leads are connected and I measure increased voltage for each lead - which is correct.
Connected the balance connector to BMS and expected zero resistance between B- and P- on BMS (according to manual) - Fail
Measurements from B+ to BMS which is only connected through balance leads:
B+ to B- on BMS: 13,1 V
B+ to P1 on BMS: 3,12 V
This is the first time I connected the BMS. I've got two of them showing the same behaviour. They could of course be faulty but I figured I'd try some troubleshooting before contacting support (if there is any).
Looks like a DALY clone. Edit: this one is backwards, seems they want you to connect balance leads first, then B-. Have you tried the multimeter in the opposite direction (swap probes between P- and B-)
With ONLY balance connector and plus from multimeter on B+
B- on BMS 13,1 V (same as B- on the cell which is connected through the negative balance lead.
B- on BMS and B- on cell pack are directly connected (tested with buzzer)
P- on BMS 3,12V
I tried the different connection order and short-circuit of B- and P- (10 seconds, both with B- connected and not) before you edited
And I'll add ring cable connectors.
well since you caught my initial post before I edited, did you try a charger? also if the BMS came with a temperature sensor, is it plugged into the NTC port on the BMS?
My identical, but DALY labelled one won't start without the temperature sensor connected, and it only starts if I supply it a charge. (I use 10A at 14.5V between B+ and P- once everything is connected - balance plug and B-)
THANKS! (y)
The temp sensor was the culprit, when that was attached the BMS behaved like expected in the instructions. Zero resistance across B- and P- on the BMS and same output voltage on P- as across B- and B+ on the cell pack
I never thought that could have an impact, and wanted to start with a minimal system (without temp & BT) to reduce complexity.
Thanks again!
It took me 3 days to work out that the temp sensor was the culprit on mine too. I'm in australia, so don't need it... guess I do if I want the BMS to work ;)
