Hey, I’m looking to add whole house AC surge protection, and I am pretty tight on breaker slots at the main panel.
I am currently completely off grid and have a split phase 240v system feeding the main panel via a two pole 60 amp breaker. I am looking at purchasing a midnight Solar MNSPD-300-AC.
Since my ac is provided to the main panel via the inverters, could I install the SPD upstream at the inverters 2 legs of AC out?
I have a 60amp AC disconnect that would be easier to connect the SPD to.
Or is there some benefit I am unaware of as regard the main panel placement?
Distance from the inverters to the main panel is about 60ft.
Thanks
-Edit just to confirm my main purpose right now is minimizing negative effects on electronics when the inverters drop from high loads. I am guessing being upstream would give less protection to my house in the event of a large lightning strike
Thanks
