Hey everyone! I am not sure if this is the right thread or not for this question.
I live in a school bus converted into a motorhome and when it gets hot outside, my solar doesn't quite keep up with my mini split AC...
Sooo, I bought a Predator 2000w generator with the idea that between the solar and the generator, I could power all of my loads and also have some excess to charge the batteries with. I have 1360 watts of solar panels on the roof.
Okay, to my main question. Is it possible to split my loads between the generator and the battery in the case that the generator can't supply all the power that I need in that instance?
For example, tonight we got home kind of late (after the sun went down) and the inside of the bus was still very hot. I cranked the mini split on and it was pulling a lot of power. More than the generator can sustain for a length of time. I'm wondering if I can change a setting on my MPP LV2424 Hybrid inverter charger to limit the power that it pulls from the generator and supplement any need with my battery. Ideally, I could control it to prevent more than 1600w being pulled from the generator and it would supplement with battery. Split the load.
It does this exact thing with solar all the time when the solar panels aren't producing enough for the full loads. Is there a way to have it do it with the generator input?
Thanks in advance! If I can get this to work I think the 2000w generator will get me by but if not, I'm afraid I wasted a bunch of money by not buying the 3500w generator.
