Hi, I know for sure that at the moment they are used to protect solar panels, so the current goes in and out, so unless I have understood the translation correctly, I don't understand what you mean.Possibly, what's your actual application?
SSRs have a volt-drop and power dissipation (hence the heatsink), exactly what the numbers are should be in the device documentation.
They are (mostly) NOT bi-directional, so if you want charge and discharge currents to flow you need two SSRs in inverse-parallel.
You may actually be better using a nice, meaty, conventional relay.
I also note that yours is marked as 220V DC 50/60Hz![]()
So just a resistive heater? That should work fine, but please make sure you have a separate overtemperature thermostat and overtemp/overpressure (plumbing) device and they are functional and also rated for DC.48V 70 amp storage tank
48V AGM batteries and a 48V water heater? The DC thing trips up a lot of people, and hot water tank explosions (*) are nothing to sneer at.Yeah, assuming that's what he meant, but why the mention of "AGM" which got me going in the battery direction.
Also, I wouldn't want to go over 50% rating on a long-term basis.
As written before, it should be used to pass the positive of a 48v battery.Is your "storage tank" a water (or sand/rock/salt) heater of some kind or energy storage (battery)?
I'm sorry but you misunderstood, the water heater has nothing to do with it! I'm talking about passing the positov of a battery through an SSR.48V AGM batteries and a 48V water heater? The DC thing trips up a lot of people, and hot water tank explosions (*) are nothing to sneer at.
(*) Yes, I know, it requires the primary control device (SSR) to fail on (or the control system hardware/software to get stuck)
AND
The backup/safety thermostat be the original AC-rated model (common mistake) and have it's contacts welded shut as a result
AND
The overtemp/overpressure valve fail in the stuck (or clogged) closed mode
AND
no-one notices that the home-made dump load is running 24x7.
However, the downside is pretty serious, and someone asking the questions above probably doesn't know about all of those fiddly details.
Google is your friend, look for hot water tank explosion.
Frank, you keep asking questions and when the answer from the experts doesn’t match your expectations you start to argue and treat people like they don’t understand your question.As written before, it should be used to pass the positive of a 48v battery.
Considering what you wrote and in order to understand, could you make a sketch of the use of the SSR?
Yes, absolutely that works. The results will depend on the load. If that’s a secret then say it’s a secret. If not help us help you by adding some more details.I'm sorry but you misunderstood, the water heater has nothing to do with it! I'm talking about passing the positov of a battery through an SSR.
Can’t really parse that picture, enable the panels whenever the batteries are connected? And then stay on until the batteries are disconnected _and_ the sun goes down?That is annexample
I wasn't talking about changing the subject, just the fact that I didn't mention any scoundrels. The intent is to understand if an SSR can make VDC voltage and current flow from a 48V 50 ampere storage tank. I think the problem is traditional from Italian to English unfortunately! I'll attach the video link so maybe you can understand how SSRs are used to protect a system. This is an example, but what I wanted to do is linked to the flow of 48v batteries. I am a beginner and as such I struggle to explain and I want to underline that I am not changing anything, but I insist on a problem of understanding through Google translations. Here is the link to the video which shows just an example of the use of SSR, and from here you got the idea of being able to apply it to the 48V storage if possible. That's all .Frank, you keep asking questions and when the answer from the experts doesn’t match your expectations you start to argue and treat people like they don’t understand your question.
Ah, indeed, a translation issue. If you are talking about a BATTERY, that's a whole different question.48V 50 ampere storage tank
What device has a 7mv drop at 70 amps? I have an electronics background, but I must have missed something.Those with an electronics background can switch electronically for less money and less than 1/2W loss.
Hello and thanks for at least partially understanding. I had inserted agm, because my aim would be to be able to switch two photovoltaic accumulators based on the battery voltage via a dry contact and SSR relays in order to use one or the other as a backup for the inverter. Looking carefully at the video, I noticed that the reason why the negative was connected to the SSR was because it wasn't working. Currently several users use SSR to save the regulator system from sudden storage disconnections. But as written before I would like to make an exchange between the accumulations. I opened another post about this.Ah, indeed, a translation issue. If you are talking about a BATTERY, that's a whole different question.
Yes, an SSR can switch a DC current (in one direction only).
I really doubt this will work like you think it will, but you still haven't given us enough information to help you properly.
What do you have, and what exactly are you trying to do? The title says AGM, different posts say 50 or 70 amps, if you are switching a battery the current could be (briefly) essentially infinite.
What are photovoltaic accumulators? And why do you distinguish them from batteries in the same sentence?photovoltaic accumulators
Would you be able to make a sketch?Someone with an electronics background wouldn't do it this way.
I mean the word accumulation, my batteries which in this case are 4 12v in series for a certain amount. 48v 110 amp AGMWhat are photovoltaic accumulators?
