You can parallel batteries with different Ah, if they have the same chemistry it's best.
the bigger battery (280Ah) will take a bit more of the load of the smaller one
Just make sure that when you connect them together the voltages are similar or you will get one battery pushing amps in the other one. (with lifepo4 since the voltage curve is very flat you will not usually get many amps flowing as long as the two batteries are between 20 and 80%, but you should still try to have them at the same SOC)
Also each battery should have it's own fuse on the positive side
