Since I changed my battery from AGM 24vDC to lithium 2 days back I am noticing an odd charging behavior. At some point in the day the voltage cycles at 28.0 when the solar power wattage drops to zero. Then the battery voltage drops to 27.4 before charging starts again until voltage climbs back up to 28.0 before cutting out all wattage from panels. It does this over and over. Incidently I do not have any settings that are at 28.0 for lithium batteries so I do not know where that comes from
Yesterday after awhile the solar disconnected entirely (the bar indicator from the solar icon disappears) although PV voltage still indicated. I understand that to be battery fully charged and thus no more charging will occur.
I just not used to this wattage from solar going on and off, it did not do that with the lead acid. Can anyone provide an answer if this is something I should expect to see?
