Sorry in advance for being a newb but need help. I have Battleborn GC3 battery. I have an Alde 3010 glycol propane heater. The heater uses 12v for pumping the heated glycol throughout the rv to keep it warm but the heat comes from propane. When I'm boondocking, the heater is having issues with voltage drop (supposedly) which causes the heater to cut off. It is intermittent and could happen within 30 minutes or could happen numerous hours later.
I heard the battleborne bms drops the voltage and that might be the cause? Is there a device that I can use to stabilize the low voltage drops so that the heater won't cut off?
