Hi, new here. We have a 24v DIY solar setup to power our pond pump. We have four 12V, 200Ah AGM batteries wire in serial/parallel to make 24v system w/a 3000w inverter. There is a transfer switch so that when the battery power drops, it transfers to 120V household current. The idea was run the pump on solar during day, and to have a few hours of battery power in the evening, when peak use rates hit. We recently discovered that when the load is transferred to the batteries, the voltage drops so much that it only runs on batteries for a few minutes, then switches back to 120V, then the battery voltage runs back up, and a few minutes later it transfers back to batteries. It seems that this is happening in AM/PM when solar production is low. During the day, it appears to be running on batteries. But, once the sun goes down we are getting no battery operation, even though the batteries are fully charged. The LV transfer was set to 23.5. The batteries are Apex 12-200. spec sheet has float 13.6-13.8, Equalization 14.6-14.8 There is no LV cutoff on spec sheet. My question is whether this is normal, or is there something wrong with our setup that is causing the battery voltage to drop excessively under load. Is it OK to set the LV switching to 22.5V so that it is below the point that the load is drawing down, so it isn't switching back and forth constantly. Yes, we are novices at this... so appreciate gentle constructive input.... Thanks. -cj-
