I have an offgrid system with 6 48V EG4 LifePower4 batteries on busbars connected to 3 Growatt 5000ES which are in turn connected to my solar array and a 24kw generator.
I'm wanting to add an independent set of battery chargers and potentially disconnect the generator from the Growatt units completely so they're always simply inverting and there is no switching between inverting and line pass through.
I was thinking of getting a few Chargeverters and wiring them to my generator subpanel and connecting their output to my busbars to charge the batteries when the battery SOC gets low. However as I understand it, when there is a load from the house the inverters would effectively be pulling from the Chargeverters instead of the batteries without a true guarantee of exceeding their individual 5.1KW output.
I called Signature Solar technical support and asked about this and they said that the Chargeverters can't be run while the batteries are under a load. On one hand that confirms my thinking of the problem. But on the other, I can't really imagine a use case where you would turn off your house load center while you charge your batteries.
Does anyone have any experience using these chargeverters in a similar way? Or have any idea how you're supposed to use these Chargeverters if you can't have any load on the batteries while using them?
