Haven't seen a definitive answer to this, so I'm double checking with the hive mind:
I'm considering getting a Delta Pro + SHP + a few solar panels. It's mainly for critical loads backup, but the solar would hopefully "pay" for the inverter drain, run my fridge, etc. It's also to get my hands around gear before going Full Monty.
Delta Pro solar charger can do 150v/1600w/15a. Check.
I can get these panels locally (400w solar panels). The are rated at 36.87v (VOC) x 4 would be 147.48v, which is less than 150v. Whew, I'm safe.
Then I read this page: https://www.linspyre.com/ecoholics/temps.html
Am I going to release the smoke from my Delta Pro? It will be installed inside, in a relatively warm room, likely around 70 deg F most of the time.
-Dan
-Dan
