boatingeurope
- Feb 20, 2020
- 3
This is my new boat 12v 100amp lipo04 battery built outa raw cells with a BMS charged by 24v 250w solar to MTTP controler.
Next stage is to setup spit chargeing with the 20amp constant current DC boost converter feeding say 15-16v to the simple 16amp solar charge controller for the lead acid starter batterys.
Current limit the solar charger to 5-10 amps will be reuseing the old spitcharger 16mm cabling to connect the batterys with say a 20amp fuse.
What do you think, issues?
What do you think?
What do you think?
