Integraolig
- Sep 30, 2022
- 6
Hey all,
Been researching a new system for a while now and with the increase to a 30% tax rebate, I'm all in this year.
A bit about my home, average 1,500kwh per mo. Panels will be a Ground Mount located 5' from the main breaker pole. We have a dedicated electrical pole outside that the meter is on, which is also the main breaker (200amp). At that main breaker it distributes to 3 circuits. Line 1 goes to a sub-panel in the home (100amp). Line 2 goes to the well pump. Line 3 goes to the HVAC (which is a heat pump system, the condenser is run from the sub-panel in the home while the rest of the system and backup heat is ran from line 3).
I was originally looking at a sting inverter (Sol-Ark 12k)... but have found that this inverter really needs to be inside the home along with the battery system. So having to run the lines from the panels to the inverter inside, and new main lines from the meter (grid) inside to the inverter... then from the inverter back out to the main breaker where the meter is, is really redundant and far to run the lines.
Question 1
Then I found the Enphase IQ8. As these are made to stay outside on the back of the panels, then goes into a combiner box (which is also good to stay outside) this seems like our best option. The only lines we'd need to run into the house is for the battery system. Correct?
Question 2
I'm getting conflicting information about the IQ Combiner Box 4 being the only networked item I need... while others say that I not only need the combiner box but also the "Communications Kit". To my understanding, the IQ Combiner box already has the Communications Kit basically built into it. Which is correct?
Question 3
How much of a power variation should I be looking at from the panel to the microinverter? I was thinking of going with Jinko JKM405M-72HL-V panels which at SCT is 405w. But the largest output microinverter is the IQ8H which is 384w. I read somewhere that 30w lower microinveter to panel wattage is the norm. But I'm just seeing this as wasted wattage. Shouldn't these match closer? Like a 380w panel with the 384w IQ8H?
Thanks all!
Question 1
Question 2
Question 3
Thanks all!
