hazardandy
New install. 54x 370W panels, rooftop. 30x panels on house, 24x on garage. Tigo TS4-A-2F per 2 panels. House is 3x strings of 10 panels (5x Tigos per string), Garage is 2x strings of 12 panels (6x Tigos per string). Growatt MIN10000TL-XH inverter for the house, MIN7600TL-XH for the garage. All 5 circuits run through a single metal conduit from the roof to the garage.
I connected all the negatives of the PV circuits to the inverters, left the positives floating, and measured each (I wanted to be 100% certain I didn't swap polarity anywhere along the chain). The Growatts have a Tigo RSS signal gen on the negative side, and when I see it blinking away with the estop pulled. All 3 house circuits measured in the 200V range, and when the positives are connected to the inverter, they go to 360V and the inverter makes power.
On the garage inverter I get something different:
-circuit 4 measures 3.6V regardless of RSS TX or not, regardless of both pos & neg connected to the inverter or just the neg. It appears the Tigos are not turning on
-circuit 5 measures 3.6V disconnected, and when RSS TX is enabled (through just neg or with pos and neg connected to the inverter), I see the meter jump to 100+V and then stay in the mid 70V.
-I removed C1-C3 from the house inverter, wired C4 & C5 into the house inverter to check if one of the RSS TX was faulty, exact same result
-each Tigo RSS is suppose to output 0.6V in the "off" state, so 3.6V leads me to believe at least one valid panel is plugged into each of the 6 Tigos per circuit, that they are contiguously connected, and that the polarity is correct. With polarized MC4s, it would've been nearly impossible to swap the polarity of anything anywhere. There's a slim chance one connector is not mated somewhere, but I'd love to narrow it down before ripping 24 panels off the roof to look for it.
Is there anything else I can do to debug? It's gonna really suck to have to go back up on the roof. Seems like the negative-most Tigo RSS on C4 is not closing, and maybe the 2nd most negative on C5 is also not closing? I'm happy to stick another box between the inverters and the PV to either run a single Growatt RSS TX or even buy the real-deal Tigo RSS TX, but my testing thus far tells me it won't change a thing.
