Hi there, I'm debating purchasing used Valence U27-12XP 12 volt 138Ah batteries for battery storage for my off grid home (three strings of 4 at 48v). I'm new to this stuff but also need to be frugal in my purchases. I will need a lot of back up storage given that I live in the desert and air conditioning needs to run all night. I have found 12 of these batteries used for around $400 each which seems to be a good solution for starting up. The equivalent in battleborn would be triple the price. I know you get a lot for the extra cost including that the batteries are new, but is seems like if I could get these to work I would be able to have the storage I actually need rather than going with a 3rd of what I need which is what I would have to do. The equipment I have so far is 24 - 320w Sunpower solar panels, 2 midnight solar charge controllers and 2 SMA Sunny Island 6048 interters.
In the video notes reviewing the 40ah Valence medical batteries Will says "DO NOT PURCHASE THE BATTERY WITH MISSING BMS CABLES!! Or the XP models." I understand that these batteries have and internal balancing system but require the external BMS programed by valence for your particular battery bank configuration. Where my knowledge is lacking is why the proprietary BMS would definitely be necessary. Would it be dangerous or would batteries just not charge properly and there would be a loss in efficiency? Would a non proprietary BMS suffice with the option of hooking up to the Valence software to check the functioning of the batteries as a group?
Any input, thoughts or ideas would be greatly appreciated! Just want to be able to build a good solid system with enough battery storage!
