Bmdale
Hi to all;
We have a circa 1997 Trace SW4024 that recently started dropping off charging before charging is complete. We live off-grid and use a Honda eu3000 generator.
While watching the current flow to the batteries on the battery monitor, charging will proceed as expected (~60+A) and then suddenly go lower and lower until it is negative and the relay in the inverter will click. After a few seconds the relay will click again, charge current will increase to, maybe 12A, then drop to negative and the relay will click.
Bulk is set to 28V, absorb to 27. Charging stops before the battery voltage reaches 28V.
When it drops off seems to depend upon the charging current setting: at 22A it charges for about 7-8 minutes, at 18A maybe 12 minutes, at 15A probably ~90 minutes, but that timeframe may be becoming shorter - haven't had time to test.
The LEDs on the interface do not show any error. The Error Codes menu does not show any errors.
I've verified the generator is outputting acceptable power.
I have tested with all PV's turned off and all loads turned off. Same behaviour.
This problem became apparent last summer. We had switched from FLA to LiFePO4 batteries in the Spring. Pretty sure we had charged to completion via generator before the summer.
I found a later manual put out by Xantrex which had a trouble shooting section which mentioned a circuit breaker on the left side. I pressed that in and it seemed to stay in but no difference in problem.
While charging the other day, for the first time ever I heard the fan come on inside the inverter. I have not heard is since.
I've read that a dirty relay can cause this issue. Assuming there's one relay for AC1 and another for AC2, yesterday, I switched the generator hot from AC2 to AC1. The problem remains the same.
Any thoughts to share?
