Tracer 4210AN Temp sensor ??
I had a look at the manual ( https://www.epsolarpv.com/upload/cert/file/1811/Tracer-AN-SMS-EL-V1.0.pdf ) and it says that the low temp protection will stop charging and discharging users setting . my question is for a lifepo4 battery i would want low temp charge cut off at say 5c but by sounds of manual that will also cut discharging at same time and 5c temperature which is not handy as discharge low temp is -20c is that just the way it is or would there be a solution i don't see or understand ??
