Scoob-SanDiego
I opened this product and used it for 1 hour to write a review.
It works really well and normally retails on Amazon for $269
Please note: This product in ONLY for Android phones (not iphone)
Asking for UPDATED PRICE: $100. (was $150) (Paypal / Venmo) with free shipping within the US.
Here is the link to the Amazon product page:
https://www.amazon.com/gp/product/B0CP8SG388
It works well, the software is simple enough and it automatically updates the firmware on the camera.
You can spot check the temperature at a specific point or you can draw a rectangle on the screen and it will give you the max/min/average temp within.
It is BRILLIANT to immediately identify any hot spot on your DIY battery or your inverter / battery / wiring setup as well as other useful tasks around
the house such as finding a water leak, identifying the stud locations through the walls, finding spots with missing insulation around the house... you name it!
Product description
PROFESSIONAL: With 256x192 IR resolution/49,152 pixels and thermal sensitivity<0.04 °C thermal sensor, the Mini2 infrared camera for android phone provides outstanding clarity and temperature accuracy up to ±2°C (±3.6°F) / ± 2 %. The 25 Hz video frame rate provides smooth panning of scenes. 50° Wide Angle great for home inspection.
POWERFUL: Full-screen temperature measurement (Center Spot, Hot Spot, Cold Spot, 3 Custom Spots and 3 Areas); 15 Different Color Palettes, help to find invisible problems more easily. Audio Alarm of Mini2 thermal scanner reminds you when the temperature is out of range. 4 adjustable image settings : Brightness, Contrast, Sharpness, Color Distribution.
BATTERY-FREE & LOW CONSUMPTION: Battery-free design so you’ll never need to charge Mini2 thermal imager up before use and its 0.36W ultra-low power requirements will run for hours without draining your device’s battery. Tested for 8 Hours of runtime on the Sony XQ-BC72.
EASY TO USE: Plug and play to your android smartphone or tablet and the HIKMICRO Mini2 IR camera is ready to go in seconds. The auto-rotation function automatically synchronizes the screen with the shot direction. The manual rotation function allows users to tap the "90°" icon to rotate the camera view until the image is in the correct orientation when needed.
RUGGED AND DURABLE: Designed to give you the power of thermal where work, live, and relax, the Mini2 thermal imaging camera features IP40-rated aluminum alloy housings, and passes strict drop tests up to 1 meter (3.3 feet). The included extension cable and USB-C Extension allow flexibility to use the camera with thick protective phone cases and to reach tight viewing spaces.
HASSLE-FREE WARRANTY: 3 Years for the Entire Device /10 Years for the Sensor. Lifetime Firmware Updates and Technical Support are included.
Product description
