Has anyone put a second EG4 battery on the back rail of their hand truck generators above the tires. It should be a simple welding project and double the battery capacity. You could use two 48 volt batteries in parallel or two 24 volt in series. It would add 100 pounds, but the hand trucks are rated at 600 or 800 pounds. It might even balance the weight for moving it around.
