Luie Lamore
I have 2 small 800 watt renogy systems with 2 60 amp controllers and 4 lithium 100 amp hour batteries each, one 2000 watt inverter and one 1500 watt inverter they are not wired into house but use extension cords to small feezers and a pellet stove when power goes out. I need any info if I can hook up both inverter to the same earth ground or do I even need it for this small systems. I can't get any support from from anyone on this so I joined this forum. I drove in a 8 foot ground rod on other side of the wall from these controllers etc. Any help would be appreciated. everything is all hooked up and working but no earth ground yet tied in. I don't even know if the 8 foot rod is getting a good ground pounded in fairly easy.
in remote Wyoming lots of cloudy days in winter so I had planned to move battery cables from one set of 4 batteries to both controllers on 4 batteries in winter so I would have 1600 watts of panels and shared controllers working together if needed due to low sunlight in winter
