agsolar
I'm looking to build a battery storage system in the order of 5-15KWh.
AC coupled to be charged from existing small PV but to be mostly charged overnight on cheap TOU.
I've been looking at a number of inverters e.g Solis and others. Many have either 1 or 2 CT clamps for monitoring solar production or direction/phase of total load in case there is 'spare' power to charge.
My question is on the phase monitoring CT - does it need to be connected to the tail of the import meter, or can it go anywhere ?
The reason is that my house was extended before we moved in. There are two consumer units - the PV inverter is connected to the 'new' CU in the basement and access to the import meter/mains entry is impossible. The charging inverter would be in the same place.
Can these inverters work without CT monitoring, in a sort of manual mode? I.e I'd accept just timed charging. Or possibly, me observing spare PV generation and doing manual top up in the day (guess I would lose a balanced demand though?)
Edit: Ive seen that some folk like @SeaGal and @SteveB123 got CTs working over RS485 to Powerline converters, and Im researching that.
But still interested in knowing the inverters can be configured to work without.
