Hi
I have a solar setup using a FoxESS 3600 inverter which is working fine but the FoxESS cloud data shows that all power generated is going to the grid - which isn’t correct.
I’ve been told that I will need to fit a CT clamp to get data on Load.
Whilst the CT clamp is only a few pounds to buy, and where to fit it seems to be quite straightforward, my problem is that the inverter is a very long distance from the meter (across the garden).
Does the clamp need to be hard wired or is there a wireless solution? Does the clamp need to be a Fox item? If there is a wireless clamp, how would that integrate with the FoxESS cloud data?
