Hello, How would you wire up a Growatt inverter in a domestic property in the UK?
Scenario 1)
The meter tails goes in to a baby consumer unit (trips to protect the inverter), from there in to the inverter, and then out from the inverter to the existing consumer unit powering the house?
And if there is a power cut, the battery & solar take over from the mains as ups?
Scenario 2)
Wire the Growatt in to the existing consumer unit (via a trip), and then from the Growatt, to a new consumer unit, and out to new lighting and socket ring mains around your house?
Ok, what I really don't understand is why Growatt call the (SPF 5000 ES) inverters off grid, when they clearly are connected to the mains.
And why they call the SPH 3000 6000TL BL-UP hybrid, when they both look to do the same job.
My wife says, sod the ups, just wire a bidirectional Sunsynk inverter in to the consumer unit, just like a standard grid tie; they wont turn off the electricity anyway!
Scenario 1)
Scenario 2)
