Has anyone with one of these server rack batteries had the issue of being unable to turn off the BMS? I believe Jakiper and SOK use the same BMS. Initially the reset button worked but only a week later and it won't shut off.
I've disconnected the positive, negative and communication cables. The breaker is off, reset button held, LEDs cycle one at a time, and then nothing happens. The screen stays on and the LEDs return to normal.
At the same time I cannot get it to communicate with my Victron Multiplus 2. I'm not sure if the problem is user error or related to the above problem.
The battery otherwise is performing perfectly.
