I have this system on order and a 100ah lead acid battery from MightyMax. This is my first build and I don’t want to ruin the battery!
Does anyone have experience with this PWM controller to know if you can change the value for when it cuts off power from the battery? I’ve read that 12.1v is where you should disconnect the load. Is there another controller you trust to have this feature?
Amazon.com : SUNGOLDPOWER 100 Watt 12V Polycrystalline Solar Panel Solar Module:1pcs 100W Polycrystalline Solar Panel Solar Cell Grade A +20A LCD PWM Charge Controller Solar+Solar Panel Connector Extension Cables : Garden & Outdoor
www.amazon.com
