NorCalPete
- Mar 8, 2022
- 5
I'm seeking advice/corrections/comments about my RV's (i.e., 21' travel trailer) solar upgrade project - my system diagram is attached. I'm swapping in two SOK-206ah batteries (prior was a pair of Trojan T-105s) and two 200 watt roof panels (prior was a single 130 watt panel), upgrading the old converter module to lithium (PD-4045LICS), and adding a Giandel PS-2200KAR inverter and TS-30 automatic transfer switch. Along with these items, I'm adding/upgrading switches, fuses, breakers, buss bars, and wiring as needed. One SOK-206 (purchased in February) came without Bluetooth, while the second one (received in May) came with Bluetooth; by my request, SOK shipped me an "old model" BMS (without bluetooth) so I can convert the newest 206 battery to match the first one. We also have two portable 130 watt flexible solar panels (mounted on PVC frames) we use to supplement the rooftop panels when parked in the shade.
We are primarily three-seasons boon-dockers, usually camping 4-10 days in shaded State Park sites during cool-to-hot weather (40-90 degrees). Currently, we use a 2500w inverter generator to charge batteries (daily in cold weather; every 3 days when moderate), run the microwave, and run the A/C in hot weather (although very rarely). My goal is to eliminate the need for the generator except to run A/C.
At home the trailer is parked in our driveway, connected to shore power (30 amps), and used occasionally as a home office. The goal is to run it on solar at home except when A/C is needed, and to utilize excess solar capacity to power one or two 120 volt circuits in my house. A 10-gauge extension cord will run from the trailer (i.e., from the refrigerator's 120 volt ac outlet) to the house's manual transfer switch (installed for my generator).
So those are my goals, along with my current plans for implementing them. Your comments or suggestions would be greatly appreciated.
