Here are my thoughts on a 1,000 vs 2,000 watt inverter, (assuming quality inverter, not a cheap one that fails to deliver its claimed performance) with a 1,000 watt inverter you will always be asking yourself, will the inverter power this or that, for some stuff like a modern TV, notebook computer, that is an easy yes, for others that draw more power it is often a maybe (food processor, power tools, etc.) by comparison with a 2,000 watt inverter you can reasonably be assured that it can power any 1 appliance that plugs into a standard 120V-15 amp outlet, as by law these devices are limited to 1,500 watts, with some allowance for higher start up inrush. Meaning if it is the only thing plugged in then the 2000 watt inverter should power it.
