brianjonesphoto
Hello all
I'm investigating the best way to charge our eletric motorcycles while camping without a generator. We have 4 bikes with a total of just under 7k WH of capacity. I'm looking to build a system that has enough capacity to recharge all 4 bikes from dead overnight. Realistically it's highly unlikely that all the bikes will be completely dead at the end of the day.
Currently we have 200 watts of solar and a 150ah 12v LFP battery managed with an Electrodacus bms and controller, and it more than meets our eletricl needs for the trailer.
What I'm considering is building a 24v 7200WH system (8x304AH cells) and adding 4, 300+ watt 60 or 120 cell panels. In theory this should give me enough solar capacity to recharge whatever is used overnight to charge the bikes with bit of a cushion.
I've done some measuring and the chargers for the bikes are only about 85% efficient from 120v AC source. I'm loosing roughly 60-100watts from each charger. That added to inverter losses is a significant amount of wasted capacity. I'm thinking about using cc/cv boost converters for a dc>dc charger to step up the 24v to the 54.6v and 58.8v the bikes need. This "should" get me at least 90% hopefully closer to 95% efficiency. With all 4 chargers running it would be appox 120amps draw from the battery.
I'm looking for some feed on this concept. Is there anything major that I am missing?
Thanks.
Thanks.
