Used Lithium Battery Info
dragondoom295
California
Hello! I'm new to solar and lithium batteries. I got a good deal (I hope) on two used lithium batteries and am trying to find out some info on them, especially what kind of amperage I can pull out of the BMS. See attached pics for BMS and battery. I was told it was a 100 amp hour li-ion, with an available 60 amp max draw from the BMS. However looking up the battery info (A123 ANR26650m-1B) I think they are lifepo4 ~80 amp hour batteries. Would someone be able to help tell me what's what here?
Also, what about the BMS amp rating and is there a way to change it or do I need a new BMS if I want to draw more amps? I'm concerned about the wire size on the batteries, they look really small. Can I remove them and solder on bigger wire?
My goal is to make a 2000 watt 12v portable solar power station/generator. I already have a 60 amp MPPT and a 2000 watt 12v inverter. Along with a sterling power BB1230 for dc-dc charging.
Once I figure out the batteries, I'm sure I'll have questions about the power station build. Thanks in advance!
Those cells look like 2500mah or 2.5ah cells. If they are in a 4s20p configuration like it appears in the pictures that would make the 50ah batteries. The BMS looks to small to use for what you want to do. 2000W ÷ 12v = 166.6 amps.
Thank you for the help! Yes, they are 2.5ah cells, but it is a 4s32p configuration. Would this be 80ah then?
Can I upgrade the BMS to a higher amp model? Or, preferably, use a high amp relay to handle the higher load with the BMS acting as the switch trigger? (https://batteryhookup.com/products/te-connectivity-ev200aaana-500a-0-900vdc) if I did this I imagine I would have to increase the wire gauge coming from the battery? Thanks in advance for the help.
Yes that would be 80ah. Yes you will be able to upgrade the BMS on them just make sure the BMS is able to be paralleled to another.
