Hey guys I'm needing some more advice, I'm looking at buying a battery from tech direct they have a couple of plug and play 48v battery packs with the bms installed 1 is a 48v Nec lifep04 5 kw 120 ah 90 % cap and the other one is a plug and play 48v battery pack with the bms installed 48v Bmw NMC Lithium nickel manganese cobalt oxide 4.55 kw 90 ah 85 to 90 % cap which one of these batteries do you think would work the best with my inverters and the 6.24 kw's of panels 24 - 260 watt panels. I have the 48 v inverters listed below.
