I have done a bit of a search and a lot of what I read is way over my head so here's my situation. I am in the process of adding solar to my sailboat. I currently have 2x 6v golf cart batteries in series to give me 225 ah at 12v as well as a 12v lawn tractor battery as a starting battery for the small outboard auxiliary, charged by shore power when at the dock and the outboards small alternator while motoring and nothing while sailing. I am going to install 2 x 400watt LG neon panels and while on the surface it may seem like way more solar than I need for the battery bank I have they do serve another purpose being as a hard top to provide protection from sun and rain as the panels are quite large. I have purchased 2 x Epever Triron 4210N mppt charge controllers (100v/40a). So, it seems to me that with 800 watts of solar and only a fairly small ( but adequate ) battery bank i'm thinking they will be charged fully well before noon if the sun is out and then I will have a lot of energy going to waste which is why I would like to use it to heat a 6 gallon marine/rv water heater. These heaters come with a 110v element but there is a work around to also install a 12v element so I can use either. So this is what i'm working with, none of the solar components are installed yet. So, my question to you folks is this, what do you think would be the best way to utilize the excess power from the panels to achieve this? my initial thinking has been to power the element from the load terminals on the charge controllers but I can not find anything in the user manual that tells me that I can do this or not. Anyone done something similar? I could possibly install an inverter and just power it that way with the 110v element and not bother with installing the 12v one but it seems that it would be cleaner to not go through the batteries at all and go direct from the panels , but I am somewhat open to suggestions as I am not at all well versed in electricity. The other part of this puzzle for me is that I am not sure of what wattage 12 v element I would be needing, I would think I would want one that was a little over the 800 watts of the two panels combined but i'm not sure.
Steve.
Steve.
