I have it vented currently with 2x2” holes at the bottom and two at the top but we are burning through propane for our heater really fast. Hoping to somehow reduce the loss of heat.Yes vent your shed with all types of battery is best practice
Although AGM do not gas in normal states, in failure they can gas, definitely need some kind of small vent
Oh cool. I have a 48V system and a Midnite classic 250. Could you give me instructions on how to program it to the Midnite.AGM can offgas Hydrogen like FLA but not as bad fortunately. Any inspector will want to see some form of venting because it applies to Lead Acid batteries in all variants.
Seach EBay/Amazon etc for "Zephyr Power Battery Vent"
They come in 12/24/48V models. Very Low power with a backflow protection to prevent air coming in.
Very easy to setup, uses 2" ABS pipe and comes with an adapter for 1-1.2" pipe.
I used one of these for my FLA Battery Box (required by code) and this was controlled by my Midnite Solar Controller via a relay.
Also, how may should I install. The shed is only 4x8. Would just one be enoughAGM can offgas Hydrogen like FLA but not as bad fortunately. Any inspector will want to see some form of venting because it applies to Lead Acid batteries in all variants.
once upon a time when I had lead acid batteries , I put them in an air tight box and had two hoses in and out.... one terminated at the bottom of my container and the other at the top. My idea was that when the batteries were warm and off gassing, that would rise and escape out the top hose. Then the bottom hose would draw air in and start a thermosiphon. Here you can see the hose nearer the front goes down and the one in the rear stays up high. The other end of both those hoses went thru a hole in the basement wall above them.I have it vented currently with 2x2” holes at the bottom and two at the top but we are burning through propane for our heater really fast. Hoping to somehow reduce the loss of heat.
