Katie33kate
- Jun 26, 2022
- 42
I have 690W on the roof handled by the victron 150/85. I have a 400amp 12v LiFePo4 battery. I’ve had this MPPT for 18 months. (since January of 2021). it has started to fail to charge my batteries up. Even in the winter, I would be back up to full by mid day. Now I am in high summer and cannot get the batteries charged up because the MPPT stops charging. (I am in the desert of New Mexico…endless sunshine).
at dawn (6 am) the MPPT kicks into bulk…this lasts about 1 hour, then drops to absorb. But this lasts for just a couple hours when the MPPT is showing 14.2 on the battery and it drops out into float. BUT…a battery monitor shows that I never get above 13.23 13.24. The monitor also shows I am at 72% when the MPPT is claiming 14.2. I have checked this with the volt meter at the battery…and the monitor is showing correct. Even after hours of drawing power for refrigerator, freezer, and swamp coole…the MPPT will not kick back to bulk. I have been down to 12.8 as measured by the volt meter…but the MPPT will not return to charge..
i tested the battery…used the inverter/charger to take it up to 14.2..then shut everything off. Tested the battery every hour for 24 hours. Of course the battery drops down to about 13.5. Then holds stead. Does not lose charge.
so…my problem is that Victron does not handle the sales/support/ etc themselves…and the seller on Amazon,( Inverter R Us) probably doesn’t actually know anything…but is blowing me off. Run this test..run that test….always with long delays between communications. If I ask a question is take a couple days before anyone gets back to me and then never answers my question….just round and round in circles. I have been forced to stay at an RV park on their electric. Meanwhile I an just getting the run around. It has been a month since the first phone call seeking support.
if, in fact, I do not understand what is happening with the MPPT…please help me understand. If I got this right and the MPPT if failing…what do you recommend to handle this seller? This cost ~$800.
thank you
thank you
