I've Victron Multiplus II 48/5000/70-50 230V, 280Ah x 50V capacity battery. The inverter allows cont. discharge 4000W and peak 9000W, that is ~80A and 180A discharge current respectively. So 200A (or greater) BMS would be fine. But the question was about connectivity with the embedded Victron charger.
Now looking for a proper BMS and realized I don't know how to make sure there's communication compatibility.
My options for now:
Rec Q, high quality, works perfect, but for a price of a kidney;
Seplos, probably works with Victron, but would like to see feedback from someone over a few years of use;
JBD https://www.docanpower.com/index.php?route=product/product&product_id=444, looks solid, supports Victron (allegedly), but need feedbacks also;
OverkillSolar, does not support Victron, but
@Will Prowse recommended it. I noticed he doesn't connect it to the charger at all. So maybe if I charge top balanced battery at 0.1C or lower to 90% capacity, it's not so needed?
That is interesting experience. Are you going to re-use old cells with a new batch? When done would like to hear about pitfalls if any.
I noticed on the scheme there's no cable between Daly BMS' parallel modules. Do they communicate wirelessly? That is weird if so.
Will look at Daly again, thank you.
I don't have solar, going to use my system to get cheap electricity at night and as a backup system in case Russians blow up another powerplant.
So scaling the battery up is the next step.
