Im trying to debug a very poor van solar conversion
Please note, I did not build this installation so I do not have build details
I have a Victron 150/35 MPPT charge controller to charge two Battle Born 12volt 100 a.h. battries in parallel.
Also Victron battery monitor with bluetooth.
Loads are Magnasine MS2000 inverter plus motorhome goodies, LED lighting, water pump, diesel heater, etc.
The biggest load on the inverter is a 1500 watt water heater.
Charge circuit is two 30 cell panels in series, type unknown
Vehicle is Turkish built Ford Transit van., 2018 model plain no windows van with closet motorhome built in
Before I got involved the complaint was the inverter stunk of burning insulation when running the water heater as a only load.
The Inverter was removed and replaced with a simular Magnasine MS-2000-20-20 almost same except has two branch breakers installed where as the original had no load breakers installed....but the installation was not finished, AC wiring left dangling. (Not done my myself)
Biggest RED FLAG..........2/0 cables directly from vehicle start battery to Battle Born’s......about 6 feet......only a 300 amp ANL fuse between Flooded Lead Acid and Lithium Ferro Phosphate batteries
Really Qualified...???......the minute I saw that the circuit was broken... comment please!!
The load shutoff switch shuts off the inverter as well as the other loads......something I would not do due to the precharge requirement as well as the fact that there is a magnasine remote installed and it is capable of shutting off the inverter
There is no inverter pre charge circuit......going to add
There is (according to manual) a rotary switch on the Victron MPPT which sets battery charge parameters, but I cannot find it‘s location in the manual or on the device, due to the other (mistakes?) I really need to check everything.....Does anyone know of this rotary switch and where it is located on the unit. Its in a cabinet with limited space and eyesight....
I have purchased a Victron Orion B2B to charge from the vehicle which I am in the process of adding
Asking for comments...
Victron MPPT battery charge settings switch location
Direct connections between FLA and LFP batteries......OK.....Iknow better....my customer does not and he doughts the need for the B2B
Comments please....
HEY....I’m a Midnight guy...
Comments please....
