Have a question on the wiring for my Multiplus II 3000(AC Side) which will be installed in a tiny house. I have read multiple forums and watched every youtube video out there, but seems like there is not a one approach concensus. Wire size will be 6/3 per manual.
- I have seen romex used including a video by Current Connected and that may be the best option, though not sure that romex would give the cleanest appearance coming from the unit.
- lots of folks using SOOW wire, my only issue there is running from the unit to my breaker which would be behind sheetrock and not sure it is rated for that
- also see some using conduit and 6 gauge thhn, however 3/4 conduit would be needed and as another user pointed out one of the holes is too big where the others are too small to use 3/4 conduit.
With that was wondering if it would be ok to wire the multiplus with the SOOW and switch to romex in a junction box. I know functionally it would work, but wanted to make sure I am not ignoring any safety issues.
Other option would be to use 3/4conduit through the rubber gromets (secured to the wire clamp in the multiplus) so I can use 6 awg THHN all the way without a junction box. I am assuming I could clamp the conduit where you could not pull out, though I would need to test that.
Appreciate any feedback.
