chadjones99
chadjones LLC
Hello, I have a question about my smart 30 Bluetooth chargers, I have 2 Victron smart 30 charge controllers, And I have noticed twice now that the battery is near 100% charge instead of both chargers ( which are linked Bluetooth-wise) backing off on the charge rate and going to float one of them appears to be shutting down charging all together while the other one stays in bulk until the very end. Is that because that one is the network host ? or what. also on the one that stopped charging near 100% one time it still showed solar panel voltage but no output while today it shows almost no solar panel power. Both systems have their own set of panels and are only connected via Bluetooth ( and of course output to the same battery ) What should the smart controllers do ? I.E. both goto float or back off and turn off together etc or one turn off 1st?
note the pictures below are of the 1 charge controller that shuts down 1st and the shunt , the other charge controller I do not have a screenshot of
