Good Morning,
My smart shunt is not working correctly and I need to know how to fix it. The first thing I noticed is it appears that as the battery is being used up it is not calculating the percent of battery state of charge correctly. I have two 100 amp hour AGM batteries so I have one of my settings at 50%. I effectively have 100 amp hours usable. When it gets down to 75% state of charge should it not have used 50 amp hours? It always shows slightly more as an example it might show 57 amp hours used. Now the second thing is it never recharges back to 100% state of charge. Now I have the Victron MPPT and 635 watts of solar and I am currently in sunny Arizona. It does go from bulk to absorption and for roughly the last two hours of sunlight it is in float mode. When the sun goes down battery voltage is 12.9. I am assuming by going into float mode and having 12.9 volts I am fully charged. I contacted the place that I bought it from and they said I needed to reset the state of charge to 100% as it has to learn what 100% is. They also said it might take a few times of doing this. I have now done it 5 times and the problem continues. So after the reset the next day it will get back to 99 or 98%. The following day it will only get back to 97% and this trend continues losing a percent or two a day. After a few days I can't get state of charge back above 90% although it is in float mode and 12.9 volts. Do I have a setting wrong? Thoughts and all comments are appreciated.
