prometheanfire
Not sure I should post a link to this here or another forum.
This helps show why a resistor is necessary when connecting a battery to a load (like capacitors in most inverters).
What a resistor gives you is a way to slow down the initial load (electron inrush if you will), allowing you to stay below a fuse rating, if you are using one (you should be).
