ArtieKendall
I just received my EG4 3000 AIO and a couple EG4 LL2 batteries (48v 100ah), and I have some newbie questions.
I've seen about a dozen videos warning that you need a pre-charge resistor because of the capacitors in inverters. I've seen even more saying to be sure everything is disconnected and/or turned off from your inverter before you start connecting stuff to it.
But I haven't seen any videos discussing the logical sum of these warnings, namely that even when everything is disconnected, your inverter might still be holding a charge in its capacitors. I did see a Will Prowse video showing that in some AIO inverters, the disconnected PV inputs had a high voltage on them from somewhere else in the unit.
So it makes sense to me that along with disconnecting the battery, AC, and PV inputs before I work on the inverter, I also want to discharge the capacitors.
Question 1: How do I discharge the capacitors safely? Can I just put a resistor across the AC out for a few seconds, the way you put a resistor in line with the battery to pre-charge?
Question 2: My batteries arrived with around 50% SOC. Can I connect my AIO to the batteries and the AC-in and start charging them, with no solar and no load, until they're at 100%?
Thanks for any help.
