OffGridMike
I am new to the forum and new to solar. I recently purchased an off-grid 2400 ft2 log home in SW Washington state. It has an existing system from 2009 and I am looking to update/upgrade. I have pretty good southern exposure and typically only use the home on weekends (twice per month). The entire system is in a small non-insulated shed and the roof has enough space for 6 panels. You can see the shed in the right side of the pic below. I am looking for any feedback. I have a few questions I am thinking about at the end of the post and would welcome any suggestions or comments. Is there anything I may not be thinking about that you would recommend I look into? Thanks for everyone's comments in advance.
My current System
Xantrex XW6048 hybrid inverter/charger
Xantrex C40 DC controller
Xantrex XW System Control Panel
Xantrex XW Automatic Generator Start
Schneider Electric Insight Home
8x, Duracell SLI6V370S flooded lead acid batteries
4x, Moser Baer MBPV CAAP 215w panels
Kohler 12RES propane generator
Proposed new components
EG4 6000XP Off-Grid Inverter
3x, EG4 LifePower4, 48V 100AH server rack lithium batteries (with 6 slot rack)
6x, SunPower 430W Mono solar panel with RIGO rapid shutdown module
Based on what I understand, this will increase both my battery capacity and solar power generation, and replace everything except my Kohler generator.
Questions:
My current System
Questions:
- Is the generator functionality sufficient in the 6000XP that I do not need a separate AGS unit?
- Do I need some sort of control panel or is the 6000XP enough to monitor inputs, outputs, batteries, and the overall system?
- The generator is 15 years old and has a lot of hours on it (partly because the existing batteries were not maintained well and don't hold much charge). Do I need the EG4 chargeverter or some other charge controller?
- Can I use my existing panels on the north side of my shed roof? If I run them in a separate string, can I connect them to the inverter and use the additional power they might generate?
- What happens if the batteries are full and the sun is shining, and I am not using my cabin for a few weeks? Do I need anything to discharge power?
- Do I need to worry about a heat source in the shed for the winter?
